I want to install a second light in the hallway. The area can be reached through the upstairs floorboards which I can easily lift. I assume they will be able to break into the circuit from the same place and it will have to be operated from the same switch as the first light which is 4 metres away in the hallway hall near the first light . I would really like it attached to a spare switch in the hall switch board but think that would mean lifting about 4 metres of floor boards in the rooms upstairs.
I also need to replace the 3 gang plastic light switch in the hall with a four gang cast iron switch which is a repro so has modern fittings.
Is this a practical job and roughly how much will it cost me for new wiring, drilling and fitting both the light and the 4 gang switch ?
