Hi all,
We've just moved in to a new house and I'm trying my best to figure out the heating system and failing miserably. The boiler is an Intergas Rapid 32 with no thermometer in the house.
I've looked through the boiler manual and managed to get it to be either set by timer, temporarily on or continually on. Everything seemed to be OK yesterday, the hot water was fine and the radiators gave out a lot of heat.
Now the hot water is OK but the radiators aren't giving out a lot of heat at all. The TRVs on the radiators are set to maximum so it's not that. It doesn't feel hot in the room so it's not that the room is at he desired temperature.
Now the other issue I can see is that the boiler pressure is sat at 0. I've opened up the valves to increase the pressure but nothing happens to the gauge!
The hot water is working as it should. When the hot water is requested, the boiler kicks in to action and the pressure gauge flicks slightly but barely above 0. I'm extremely confused.
The system has a BoilerMag installed as well if that makes any difference?
