Sash window weights clashing
4 Jan 2009
Herefordshire
im restoring a large sash window.
K’s
The weights are a square cross section and when one comes down it can clash with the other weight.
Is there anything cleaver you are meant to do to prevent this.
My other windows have round cross section weights
Thanks for the link. Will study that.
They clash where the hatch is.
And the hatch is Meant to assess both weights. So you can’t have that wood that far down.
AndyPRK, good evening.
A square section sash weight is a wee bit unusual, I cannot recall seeing one ?
Can I suggest you contact Architectural Salvage yards and see what is available?
As an aside? some / most sash weights are stamped with the weight [In Lbs.] you may have to weigh a square weight to get 2 of equal mass??
If the "pocket" of the sash is narrow, then frequent "clashes" can occur, rounded or bullet shaped weights will bounce off each other, the square section you have will simply jamb up ?
I can recall in a School in Edinburgh there was a very large staircase window, each sash had 2 weights each side per sash so there were 4 weights in pocket, they were all bullet ended, no clashes even with the two weights of a lower sash "bouncing" because of the rounded tops deflected past the top sash.
Ken.
Yeah. I think they are square section to get maximum weight.
These ones aren’t stamped with weight.
Other ones in the house are
Are the weights hitting each other at the "pocket" where you access the weights? if so then the length of rope is excessive on both top and bottom sashes
Ken.
A couple things?
1/. I have never seen the division ply "Wagtail??" on any sashes i have worked on or indeed seen this "Wagtail" in any technical books that I have read?
2/. It sounds like the top sash rope is too long?
Ken.
The wagtail comes down to the pocket. It has to finish below the top of the weight at its lowest point.
Are you sure its nit sbagging on the top edge of the pocket?
The wagtail is made of thin ply and hanging loose so that it can be pushed out of the way to get the top sash weights out.
Cast round weights were common, modern ones are often square.
Weights for double glazed sashes are usually lead or solid steel.
I wanted to clarify that when both sashes are up, should the weights be level?
Is that the way it’s normally done?
Interestingly one side is ok!
This window hasn’t be touched in 55 years
Yeah I saw it hitting the weight today.
Though I was blaming the hatch over the past few days.
Notch7.
A question, it is a long, long time since I re-roped a sash window. over 35 years? [time passes fast when you are having fun?]
Is the "Wagtail" a relativity new progression? or is it restricted to certain types of such windows.
As posted I have never come across such a thing??
Ken.
The weight position is normally 1 at the top and 1 at the bottom.
The only rules are that weight stops before the pulley and stops before the bottom cill in the box.
