We moved house about eight weeks ago; the house has a WB37CDi combi boiler which is about 12 years old. Although the previous owners provided a Gas Safe Certificate, I decided to have the boiler serviced as, according to the service history in the Installation Manual, the last service was about nine years ago.
I employed the same GSR as my son (who lives nearby). He came with a young lad who did all the work (presumably a trainee as the Gas Safe website only lists the person I employed).
The service took about 15 minutes and consisted of attaching an analyser and taking some measurements. The results are as follows:
Operating Pressure 16.08 mB (I queried why it wasn't 20 mB, but he said it was OK.)
CO2% (High) 9.2
CO ppm (High) 63
CO/CO2 Ratio (High) 0.0006
No readings were taken at Low output.
Is this acceptable?
The condensate trap was not removed and cleaned; neither was the Magnaclean.
The Gas Safe man drew my attention to the cover containing the sight glass and said that there had been instances of the glass cracking and the boiler wiring being damaged (presumably by flames escaping). He suggested that the cover should be replaced by one without a sight glass (cost about £60). I queried why there had not been a recall.
Is there any truth in this? What would you suggest I do?
CO2% (High) 9.2
CO ppm (High) 63
Is this acceptable?
