Garage shelves
8 Jan 2009
Glengormley
I had racking in the garage, which was fine when I wasn't using it as a garage, but sticks out too much to get a car in. I now want to get one in, do maintenance etc, so need to put shelves up instead.
Anybody have any thoughts as to what's best/cheapest/easiest? It won't have to carry anythgin very heavy, just the usual tins of paint, tools, general bits and pieces etc.
In the past, I've usually made my own like this:
- but it's a bit of work, and it might be easier to use those B&Q slotted uprights and brackets that hang from the slots... ?
I'd be tempted to go with slotted bars on the walls as you say
It can be a pain but once they are up they are there for good and shelves can be adjusted
You can get a drop down table that fits spur shelving so it is pretty versatile
Twin slotted is what I have , Spur is the name, cheaper copy is Sparring , slightly thinner uprights but both brands interchangeable.
Thanks both – OK I think, as you say, twin slotted stuff is the way to go. I reckon 220/225mm will be deep enough for me.
So the next thing is the actual shelves. My local supply yard seems to have two offerings – planks (I’m sure that’s not the technical term :LOL:) or this stuff
Not sure if actual wood will cross bigger spans between brackets without sagging etc, or if the Dekaply stuff will be rigid enough... what did you use?
I have a fair bit of twin-spur and conti-board shelves in my workshop. I use that for storing my timber.
If you don't need storage for long stuff, then it's worth looking at B&Qs cheap kitchen wall units too. I have some of these too, they're cheap, easy to hang and reasonably strong. You can put doors on them and stop your stuff getting full of dust etc and they look better. I have some that are heavily loaded, for those I just fix a batten to the wall underneath to take the weight as otherwise everything is hung from the top of the cabinet and they will sag over time. For tool storage I've added some extra shelves so I have some narrow spaces to put chisels etc in.
Store most my tools in the ceiling .
Cool, I wasn't sure if you'd just done it because you wanted to. I have it vaguely on my list to get all my power tools into some similar space.
