Hi, my tap is dripping from the spout, when I push the cold tap forward a tiny bit it stops, but not if I push the hot. Does this mean I need a valve for the cold tap? Thankyou, Jeanette
Yes, replace the tap insert and all should be well.....its not a bad idea to have another insert in stock, together with the spout 'O' rings - which you will need in due course.
Gather spares while you may!
John
The sum of the parts being more expensive than the whole is what it's all about these days... Cheap "shed type" fittings are just not worth repairing... A whole new tap is the same labour to fit as mucking about repairing the old.
