    Dismiss Notice
Dripping Franke tap
Discussion in 'Plumbing and Central Heating' started by jeanette63, 7 Sep 2019.
  1. jeanette63
    jeanette63
    7 May 2009
    60
    Thanks Received:
    Glasgow
    Country:
    Hi, my tap is dripping from the spout, when I push the cold tap forward a tiny bit it stops, but not if I push the hot. Does this mean I need a valve for the cold tap? Thankyou, Jeanette Screenshot_20190907-161040.jpg Screenshot_20190907-161014.jpg Screenshot_20190907-161040.jpg TV Screenshot_20190907-161014.jpg
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,759
    Thanks Received:
    4,441
    Northumberland
    Country:
    Yes, replace the tap insert and all should be well.....its not a bad idea to have another insert in stock, together with the spout 'O' rings - which you will need in due course.
    Gather spares while you may!
    John :)
  4. jeanette63
    jeanette63
    7 May 2009
    60
    Thanks Received:
    Glasgow
    Country:
    Thanks John, I'm thinking a new tap would be cheaper than buying all those for a pretty old mixer tap
    • Like Like x 1
  5. Burnerman
    Burnerman
    7 Feb 2008
    22,759
    Thanks Received:
    4,441
    Northumberland
    Country:
    Fair comment indeed!
    Avoid Chinese rubbish and unbelievable bargains , go for a reputable make......you get what you pay for.
    John :)
    • Like Like x 2
  6. dilalio
    dilalio
    20 Mar 2009
    7,338
    Thanks Received:
    1,131
    Potters Bar
    Country:
    The sum of the parts being more expensive than the whole is what it's all about these days... Cheap "shed type" fittings are just not worth repairing... A whole new tap is the same labour to fit as mucking about repairing the old.
    • Like Like x 2
  7. Madrab
    Madrab
    4 Oct 2012
    7,839
    Thanks Received:
    2,200
    East Renfrewshire
    Country:
    +1 .... we're so used to a 'buy cheap, use up and throw away' culture these days. Whatever happened to 'buy quality, use, repair and re-use'
    Your tap is of much higher quality than the cheap ones that last a year or two and as such will last a lot longer with access to spares.
    If the tap is in good condition then no reason not to strip it and clean it, replace the parts needed and get at least another 5 years out of it.
    • Like Like x 1
  8. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,383
    Thanks Received:
    1,895
    Hertfordshire
    Country:
    That's the bit the customer never understands.
    Andy
    • Like Like x 1
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
