Plasterboard flanges
22 Apr 2014
UK
Is this right? Socket once screwed in isn't flush like it would be with a drylining box. Is this to allow for plaster skimming?
Yes that’s the idea. Friction holds the box in place until you install your socket front then the socket and box clamp either side of the plasterboard.
In reality however, you’ll try and push your socket back and the box will fall out and you’ll lose the little flanges down the cavity and you’ll get really angry on about your 4th attempt. Truly awful product and something I will never use.
Yeah, I just predicted that outcome based on the test fit I just did on a spare bit of board. :cry:
Why don't they make drylining boxes for triple sockets?!
Think I'll use a pattress box instead. Not a fan of surface mounting, but its going to be behind a tv unit so won't really be seen.
Use Gripfill or similar to glue the flanges to the box - allow to set - and then the flanges to the plasterboard.
Loop cord through the box holes so you can pull it forward. Knock out the cable holes first.
Or ditch the 3-gang socket and fit a 2+1 plasterboard box with a double and single gang socket in it.
Clicky
How would the wiring work in that... existing cable into the double, then a short length from the double into a single? This existing socket is a spur off the ring main, is that ok?
If it's a spur off the ring, you could fuse it down to 13A then two sockets is no issue, or use 4milli cable.
OR, get a triple CONVERTA or CONVERTER socket, which is designed to fit over a double or single flush box.
Check which box you need before cutting a hole in the wall.
OR, get the triple metal box, locate a wooden stud (upright), notch it out with a hammer and chisel, and screw box to it.
Because they're not a standard accessory.
I'm not really sure what a 'standard accessory' is. I would have thought that a more credible explanation is that triple sockets are not a commonly used accessory, such that the market for related 'dry-lining boxes' would probably be too small to be of commercial interest to manufacturers/suppliers.
Show me where BS 1363 defines any such accessory.
