- Joined
- 8 May 2017
- Messages
- 10,639
- Reaction score
- 2,868
- Country
Hope your right John. I wonder why did the system not fill via the vent pipe.I hope I'm not losing the plot here but I'm sure the 22mm vent pipe was allowing the tank to fill, rather than the feed one......someone up in the loft to see would have been useful! The 'spout' of the vent pipe will be wet, though.....maybe that's a clue.
Once the system is full, water needs to enter the radiator circuit via the 15mm feed pipe - if no water can pass through it then the rads won't bleed.
Please let me emphasise - the vent pipe must remain clear and unobstructed at all times but I doubt if that one needs replacing.
John![]()
If it is blocked ,mains pressure would fill the f&e via the feed. The Op was earlier getting some water into the system ,so the feed isn't 100 % blocked.
