Pyronix euro 46 program.
don't know how many terminals you have on the contact you have got.
you should be able to see the reed switch connection going to two of the terminals.
Yer there is 4 screws on the back the silver ones have wires off them and the rest have nothing. I did it the same as the one I put in on the front door. So it must be faulty
I could do with a bit of help. Going back to the original post here I have had my shed changed but when my alarm has been wired back in I get the following fault. Connect the tamper wires and it sets off my rear alarm bell. I have had to disable my shed for now. Is there a setting for this to allow a door contact only with no tamper.
What happens if you just put a link in the control panel end in the tamper terminals for that zone ….is there 12v connected to that cable .? As a tamper loop is a negative loop , if there’s a short to 12+ it could cause an issue
So it was still going off until I noticed there was a wire for a speaker I have in there that was in the wrong connection. All connected but I cannot remember were to connect my speaker for the shed now.
If it is a speaker ….and not a sounder ….as below
