Yet again, I have not thought this through!!!
Ordered two patio doors and two windows, triple glazed, timber frame, and then found out that the heaviest of these is 230kg, and about 3m by 2m! The mechanical offload truck can't get into me so I am probably going to collect by hiring a dropside cab and getting the factory to drop the pallet on the back, and if I can get one with a tail lift I should be able to use that as a bridge, that will help with the first problem, which is getting it up the ~1m height difference between driveway and the front of the house. My plan is to take each unit off the pallet individually, and carry one at a time to the rear of the house, as the only access is down a side path about 1m wide. I am hoping that I will be able to lift out the sliding section and move this separately, which would cut the weight of the heaviest section down to say 130kg-ish.
As I can't get a hold of any Kryptonite I will obviously getting help to do this, but I don't have a lot of able bodied people I can call on. My brother will be there, and we have moved an old cast iron piano between us before, which was probably around 250kg, but a Piano can be set down and doesn't have the tipping risk. Suspect this will need some more bodies, at very least to stand at each side to prevent it tipping. Also thought of trying to rig up a dolly of some sort.
Wondered if any of you have experience moving a door like this, or something similar, and have any tips or tricks, or thoughts on how many bodies required!
Thanks.
Thanks.
