Hi all, help needed!
We had an old fluorescent light in the garage and wanted to replace it with a modern LED strip light. I bought one of these from Screwfix:
https://www.screwfix.com/p/lap-single-5ft-led-batten-white-30w-2700lm/1079v
I’ve removed our old light and was expecting the power cable twin and earth and the switch cable - but found a third twin and earth connected to the light that just goes into the wall towards the house.
On the new light fitting there isn’t an earth terminal, just live and neutral.
I’ve connected all the wires into the right live/neutral terminals on the light fitting and left the earth. It’s a plastic light so I assume the earth isn’t needed?
When I turned the power back on, the light comes on straight away and if you press the light switch, the power trips on the RCD.
No matter what I do, as soon as I add the switch cable it trips.
I’ve left the switch out so at the moment it’s “always on” which isn’t ideal.
I’ve done some searching and could it be something to do with the neutrals? Do they need to be connected in a terminal block rather than via the light fitting?
So the cables I have are:
White twin and earth that I assume is the power
White twin and earth for the switch
A grey twin and earth that goes into the wall and not sure what it is connected to.
Any help would be appreciated.
Thanks.
Thanks.
