Hey,
reaching out on here as I’m a bit lost in regard to diagnosing the issues I’m seeing and I’m no electrician.
We had nest installed, 2 thermostats of which one does heat and one does heat/water. The heatlinks are wired up to the tank junction box (new build so fairly new system) and we have an ideal logic h15 boiler with a weather compensator.
If we trigger the heating/water via the app/thermostat we hear the heat link click and actuators turn on/off so everything seems to work as expected. However, it seems as though the boiler is constantly ON so it never goes to 00 because the hot water off wire isn’t doing anything which is leading to the boiler overheating and then fault coding. I’ve taken a look at the heatlinks and the satisfied heat and water are not hooked up, but I’m told this is normal? I’m also told the cylinder thermostat should handle the hot water off signal and the nest just controls the valves?
Any help greatly appreciated. The tank is an SPlan dual zone I believe.
