- Joined
- 26 Aug 2016
- Messages
- 6,833
- Reaction score
- 1,010
- Country
Yes but it wouldn't comply with electrical regs, the box needs to be securely fixed. The face plate screws are pulling on the backbox so you'd have to be very sure of the connection, especially when you add on an end user pulling out a plug.could you stick metal back boxes onto a recessed insulation board with a bit of the pink foam?
That's why i only went for the approved solution. On the uninsulated internal walls i fixed up a suitable noggin and fixed to that.
Yes the added value of fixing the plasterboard costs a lot. Probably due the smaller market which can stand a higher cost to save the labour.appears to be far cheaper to get the insulation and the plasterboard separately.
No it's exactly the sameI can get the 50mm celetex boards for just under £20 each. The same in kingspan is approximately £8 a board more. As i will be requiring approximately 30 boards is there any benefit in spending extra money on the kingspan?
