Rendering externally so denser = better...or so I read.7n exterior? Why
Aye, made a nice change from my old terrace where the SDS had to come out for every other job! Could drill a hole in thermalites with a spoonCertainly easier than drilling into brick but you wouldn't normally find brick walls internally nowadays.
Just for consideration... when I built I chose 3N blocks for both inner and outer skin rendered on the outside with a 100mm cavity and rock wool batts. My reason was this is standard construction and cheap. Went for this as did not want to use thermolite/breezeblocks internally as I’d be hanging kitchen cupboards on it and thermolites are made of cheese.
BC had no issues with U values.
Why not? Much easier to render.7n exterior? Why
Because the designer is a ****, like asking for 45mm Celotex, crappy lightweight blocks and a rubbish God awful partial fill.I can't understand why you have got someone to specify materials, had the specification approved (or sending for approval) and then are taking about doing something completely different
I discovered (much to my delight) you can buy 7n lightweight fellas which we used on this job...
They are coded with a different spray to the 3.5n fellas so you can define, as they look and feel very similar.
Yes. 7n light-weight.Are they fibolites?
Why don’t you rate GRP flat roof? Thought it stacked up pretty well against other coverings.....Like when they ask for GRP flat roof coverings.
Some designers are best ignored.
As long as the temperature is holding steady at 21.3 degrees C, the air moisture content level is constant at no more than 44.6% and the boards have been kiln dried 8 minutes prior to laying - then fine.Why don’t you rate GRP flat roof? Thought it stacked up pretty well against other coverings.....
Sometimes in some cases yes, like some builders and some people who comment on here you could saySome designers are best ignored.
