- Joined
- 8 May 2017
- Messages
- 10,554
- Reaction score
- 2,819
- Country
Not sure if that's a good thing or not tbh.
I can't really make a definitive decision as to whether it was a shock or tingle,
I never changed the ssitchbi.
In the case of the use of incorrect terminolgy, I often get taken to task here for saying that "we all knew what you meant", but is it not again the case with this abomination of typing (or maybe 'predictive text gone mad'?!) that "we all knew what he meant"??Well if we knew it was a ssitchbi , that explains it all![]()
Indeed a possibility. In fact, IF it were a 'real shock' (and that now seems uncertain), and IF everything we've been told is correct, then that could well be the most likely explanation.Reversed Phase-Neutral?
That's good to know. However, that's only the sockets, and doesn't in any way prove that the N and L of the lighting circuit are not reversed at the consumer unit end.I have one of them and have fitted a few sockets in the house. The neutral and lives are not mixed up On the sockets.
It will be interesting to hear what you find.I will fit a new switch the weekend and carry out further tests.
As I said, it's amongst the most likely of explanations IF the OP did get a 'real shock'. However, as has been discussed, that does not now seem to be a certainty, so another possibility is that there is nothing wrong with his installation at all - although one obviously could not conclude that without some (inspection and) testing of the lighting circuit.Great. Well RF's diagnosis sounds the most likely.
I think I have an explanation for this:ssitchbi
