SCART socket, if you can spare the space.
Nozzle
Have you looked at the 25pin RS-232 plugs and sockets that were the universal computer connector a decade or three ago.
Like this
https://uk.rs-online.com/mobile/p/d-sub-connector-kits/7659561/
As I suggested in post 4, or did you not read it?Have you looked at the 25pin RS-232 plugs and sockets that were the universal computer connector a decade or three ago.
Like this
I have nothing to add I'm afraid, but I do have a level of intrigue to satisfy...
What's it for?![]()
Is space really as limited as you've implied - e.g. could you not use two 9-pin ones? ... and does it really have to be all that 'waterproof'?Lighting for a 1:10 scale Offroad RC car.
Why does 9 LEDs need 18 pins - would not 10 be adequate (1 common plus one for each LED)? Anyway, what I was asking was whether there was not any other space, anywhere, given that a 1:10 car is hardly a 'matchbox' model!Well it needs to control 9 leds, so yes, it needs a min of 18 pins. IP55 rating would suffice, and there is less than 1 inch of space available (length)
... and do you really need IP55 - after all, that's more than would be required in, say, a bathroom.
I did. But I used a proper and more specific term. There are many what you call “D-type connectors.”As I suggested in post 4, or did you not read it?
Indeed, as I said. In fact, do you really have 9 LEDs which all need to be independently controlled? On a full-sized car, virtually all of the lights come on in pairs (or even triplets). If your '9' include any pairs (or triplets) which always come on together, then you could reduce the number of pins even further.Hmm, hadn't thought of that, so maybe only 10 pins required.
Fair enough - that's rather more dramatically 'off-road' than I had envisagedYes, it goes in the sea. (shallow part) ...
