- Joined
- 27 Jan 2008
- Messages
- 28,953
- Reaction score
- 3,541
- Location
- Country
As you say @JohnW2 with my oil fired non modulating boiler having a programmer feed a thermostat and thermostat feed a zone valve and zone valve feed boiler and pump is fine.
But with a modulating boiler you don't want to be switching it on/off all the time, so the zone valve is not controlled by the thermostat, it is only controlled by the programmer, so there needs to be a way to switch off the boiler once all zones are satisfied, to stop it cycling all summer, easy way is a thermostat in a cool room which is always heated has no outside doors, or alternative heating normally on the entrance floor, it is set to only switch off the system on warm days. But clearly this room would not be part of the zoned system but heated at all times.
But the ebus thermostat has an added advantage in that it allows the boiler to run cool before starting to cycle, so less heat is lost through the flue, it can also control a sample room rather accurately and be connected to weather monitoring, so it would be better placed in the main living room, and the lock shield valves setting so this room needs heat for longer than any other room in the house, but it clearly can't be a room controlled by a zone unless there is a method to switch to some other thermostat when that zone is off.
Using Wiser, Hive, EvoHome, or Tado each TRV head is a zone, and the thermostat is designed to keep the boiler running if any room wants heat, Hive is an odd one out as it does not use the ebus, but relies on the boilers own algorithms to turn down the output, so with Hive two wall thermostats could be connected in parallel, although not really required, as long as a TRV has sent a demand for heat in last ½ hour in theory it should run, does not matter how hot the room with the thermostat is, but what is the point having block zone valves when every room is it's own zone, kind off defeats the whole idea.
So assuming nothing more than a simple TRV in each room, so TRV only stops over heating of any room, just can't see how two zones valves will work, and once you start fitting programmable TRV heads, then the zone valves become pointless.
