Hikvision CCTV not showing on app but cameras working fine
20 Dec 2017
i've got a few cameras at home, suddenly they stopped showing on the app on my phone but the cameras and everything are working fine. i knw this because i plugged a monitor into the recorder unit or wtv its called and it all displays and records just fine.
i'm thinking its an internet connection issue but have no clue how to troubleshoot effectively.
i did some basic things like that out ethernet cables and plug back in and reset router, nothing worked...
someone else fitted it for me and he told me to delete the device off my app and re-add it and expected it to work but it is not working.
pls can someone help?
Which app are you using?
if ivms, chances are your external ip address may have changed?
Ok. So I have and also the new hikvision app. Doesn’t work with either one.
About the external IP. If that’s what happened, how do I fix it?
Tried both mate was using ivms initially. Tried the hikvision app recently cos thought it might fix it.
Neither show cams
How long have you had the cameras on your app? If only a couple of years , at the top of iVMS menu what colour is the cloud ?
on a computer or smart device connected to same network as the dvr/nvr, type in the browser whats my ip.
If the ip address in the app is different, then change the ip address to the new ip address.
If its the same check your router has the port forwarding set up.
On Hik Connect you need to check the dvr/nvr is setup correctly, if your ip address keeps changing you should look at hik connect or using a dns service to update the ip address of your system to the app.
Lots of you tube videos on this if your stuck
Thanks mate. Going to try this stuff asap
Ok so on the dvr/nvr ...go to config/ network / advanced ....does it show machine online ?
Ok. Couple of findings. On the ivms app. I can see the device only when I go to add an online devices. Not in the devices section.
Also. When I go online and type what is my IP address. It doesn’t match the one on the dvr or on the device settings on the app
If it’s a cloud account ....on a iPhone you log in via the cloud button on iVMS ....it’s different on iPad it adds it to device list on ivms... what device are you viewing it on ?
