- Joined
- 27 Jan 2008
- Messages
- 28,031
- Reaction score
- 3,402
- Location
- Country
If anyone builds on a flood plain they do one would hope know what they are doing, and take measures to stop or reduce damage due to flooding.
However the problem is not just the building on the flood plain, but building near rivers further down stream, where years ago a storm would be absorbed by flood plains so water had a longer time before it reached the sea, now rain today, flood within hours because no reservoir to hold water back for a time.
OK we do build reservoirs like lake Vyrnwy which could be used to hold back water, but to do that they would need to be kept only half full, so then in summer there could be a water shortage, and the reservoir is owned by a water authority to supply fresh water, not the government as a flood defence.
I am lucky in a way, I live up stream so the Banwy may get high, but not for long, the local railway did cancel one train at 11 am, but by midday it was going down again. But further down looking at days not hours for water to raise and fall. And flooded fields in Welshpool can save Shrewsbury from flooding.
In Flintshire it was actually the county council who caused the flooding by dumping spoil when building Theatre Clwyd on the Alun flood plain to turn it into a park, OK that was some years ago, but they can hardly then complain if some one else does it.
If building is allowed on a flood plain then it should include a reservoir so loss of flood plain does not cause flooding further down stream.
Having Vyrnwy reservoir build by Liverpool controlling the flooding of Shrewsbury means Shrewsbury has very little control of how much water is held back, and it seems Vyrnwy reservoir could release water into the Dee instead of the Seven, but Bangor on Dee also has flooding problems, but then Bala could hold water back, Liverpool has apologised to the Welsh and said how they did not need all the Welsh reservoirs they built, so the water level could it would seem be dropped, but all the flood control needs to be in one authorities hands not spread out so one has to send requests to the other.
As a p.s. the flooding in Mold was made worse by the old now disused railway, which becomes a second river when the Alun gets too high, it always has done, then they build two supermarkets, and a fire station with a massive underground complex underneath it. Why when Rhydymwyn is so close?
