- Joined
- 6 Nov 2008
- Messages
- 831
- Reaction score
- 16
- Country
Would i need to submit drawings?
Ok
Any idea what the costs are or is it different for each council?
The fees for Planning applications are the same across all LPA’s... £103.00 for a LDC (proposed use) application or £206.00 for a Householder application. The fees for Building Regulation applications vary amongst Council’s and as well as private Building Control/Approved Inspectors should you wish to go down that route. Check your Local Council for more information on fees.
Usually yes and at least existing and proposed plans. The amount of information submitted will depend on what type of application you decide to submit... both to Planning and Building Control.
Good luck!
'I would like to submit plans to the council to carry out the works to complete this room and currently have the floor up to install insulation between the joists. ' - that is what you saidWould i need to submit drawings?
'I would like to submit plans to the council to carry out the works to complete this room and currently have the floor up to install insulation between the joists. ' - that is what you saidFor bldg regs approval that would mean a Full Plans Submission if you are submitting drawings. A Building Notice is the alternative if you really know what you are doing and can risk Building Control approving it after things are built .
As I said , if you want to submit drawings that will be a Full Plans Submission as far as building regulations are concerned.
Following on then ,you will probably be looking for a local architectural technician to prepare your drawings.
Why would planning be necessary when the OP is not carrying out a conversion, rather it has already been done?Be weary of any potential Planning applications, in particular PD and Article 4 directions. I dealt with one a while ago where the previous owners had carried out a part garage conversion. I had been instructed to submit a LDC application for a rear extension for Planning to mention the existing conversion required formal approval as there was an Article 4 direction in place. They advised to put the garage back to how it was or submit a formal application for it. You may well be ok and no need to worry about Planning at all, but no harm in checking.
Good luck!
Don’t you want to swap the garage door out for a window?
Ok
Spoke to planning who said it wouldnt need planning permission but just building regs. Spoke to building regs who said it may need planning permission!
Building regs said to make an application and pay £258.00 then they will come to site to check all is ok.
Is this the norm?
