drill size for extractor
26 Feb 2005
Gwynedd
I want to drill for an extractor in the bathroom. The hard plastic tube that goes thru the wall is 107mm in diameter (although the installation leaflet says to drill a 100mm hole!). Is it wise to get a 127mm core bit or will the 107mm size be OK (ie do you actually get a slightly bigger hole than the core bit?)
I got caught that way because modern extractors need a slightly bigger hole than the old duct.
I'd make the hole a bit generous and smudge soft mortar onto the inside so when you push the tube in it presses to a close fit (if you have a cavity wall, block the cavity with cardboard or loft insulation to prevent scraps falling inside). Turn theduct and you will be able to pull it out when the mortar is set to remove the scraps.
It is easier to pack a wider gap than a narrow one.
Tilt the duct slightly so any rainwater or condensation drips outside.
We stitch drill ours, so we just mark around the pipe and drill generously. Foam works better for filling any gaps.
