Hi, I wonder if anyone could advise?
I have a worcester greenstar junior 28i combi boiler (pretty old - nearly 15 years?)
I haven't really been vigilant with the servicing to be brutally honest. However the boiler seems to have worked well over the years. But now I have a problem.
I recently had my kitchen done up, and the fitter put in a low pressure mixer tap.
The tap, when in the 'Hot' position does not appear to be firing the boiler? It does sometimes, but it's intermittent.
When the tap does NOT fire the boiler, I have found that if I turn on the Bathroom hot tap as well, then THAT will fire the boiler up, and when I turn it off the boiler stays fired up while the kitchen tap runs, and it then works fine!
Obviously running upstairs every time I want hot water in the kitchen is a bit daft, even though it works, but can anyone explain why this happens? is it an easy fix, or do you think a new boiler will be the best solution, given the age of this one?
i must admit, the water doesn't seem to get as hot as it used to, but if it's an easy fix I may persevere but I feel like I may be just delaying the inevitable new boiler.
Any advice would be much appreciated folks!
