Is God a brexiteer?
That will be the non existing god then
Look around your home ......floor coverings, walls, furniture everything in fact .......its a little unerving to realise they are all the products of someone's thoughts.
The carpets, curtains, paint, windows doors everything in your room is tge products of someone's thoughts and actions including the tele ...the tablet or computer everything all the products of intelligence.
Scratch the walls....... scratch your furniture ....do they heal themselves does the scratch dissappear ? You know the answer to that, scratch yourself what happens ?
The absolute complexity of you, your bodies complexity is so complex there is nothing to compare with it ......thats blind chance ? Just random ?
Unpalatable as it may seem to you their is obvious design in the natural world ...... Absolutely no question .....design requires a designer.
:rolleyes: well I put waxoil anti corrosion coating on my cars and that self repairs itself if it gets scratched
Says so on the tin ;)
:cool:
Can you prove they exist?
Yep. Just chance.
Nope. No design. Just chance.
Ooops! Bad luck.
Which of the three thousand gods do you not believe in?
Yep. Just chance.
Ooops! Bad luck.
Think about it, your muddying the issue I'mnot getting in to a theocratic debate about the identity of the cause of the effect, but the effect is clearly seen so what's the cause ......many many scientists believe and acknowledge the fact of intelligent design ...Google it !
Also the anthropic principle. ;) Effectively things wouldn't be as they are unless they were. Best look to the web for a fuller explanation
