- Joined
- 27 Jan 2008
- Messages
- 28,454
- Reaction score
- 3,457
- Location
- Country
Taken from 'A' level text book, is there any way it can work without a ballast?
For a fraction of a second, perhaps, but I imagine it (or something) would soon 'go bang'!Taken from 'A' level text book, is there any way it can work without a ballast?
Seemingly not - at least, not infallable proof readers.One has to ask how some thing like this arrives in a text book? Don't they have any proof readers?
We installed several fittings would have been 70's which were in service for a long time, certainly well into 90's or possibly 00's which looked exactly like this. A 2 part box just big enough for a starter and connector and a pair of super slim arms for the tube holders about 3" below the ceiling. Instructions warrned about the heat and not to mount on papered ceilings and a massive warning about polystyrene tiles. No I never did know how they worked until we refurbed, it turned out the red and black wires [L&N] were around 40Ω each. I only recall changing tubes once and that was because one got broken and the improved light level made us realise how they had deteriated.View attachment 190213
In the time they were there, one of the ceilings had not been painted and there was a definite brown mark from the heat and they creaked a lot while heating and cooling.
Quite so but in the fitting I referred to they just looked like braided insulation so appeared to be exactly as the drawing.There is nothing in the diagram, which suggests it uses restive ballasts.
There was a resistive lead used in car ignition systems as well
There was a resistive lead used in car ignition systems as well, normally from 12 volt battery the lead would give you 9 volt at coil, but when starting the battery volts would drop to 9 volt, so when cranking coil connected direct to battery, so coil always at 9 volt. Seem to remember Ford used the resistive lead, and BMC used a resistor bolted onto the coil, it was common when the resistive lead failed to convert to BMC (Lucas) system.
