Vailant Ecotec Condensate Pipe Leaking
6 Nov 2008
Hi All
The pipe that cups under the condensate outlet on the boiler is leaking.
Its white plastic with couplers and bends that lead through the wall to outside
Is this what would normally be fitted or should it be some flexi pipe or silimlar?
Cheers
Normally solvent weld pipe (some people call it glued).
Several times I've looked online to see if polypropylene 'push fit' overflow is approved for use on condensate, and can't recall seeing definitive advice.
Some opinions say the acid could rot the rubber seal in the fittings - but surely there are also rubber seals in the 110mm downpipes and underground pipes that the condensate discharges in to?
And inline neutralisers like those made by Salamander, Calmag or Scalemaster have rubber seals too.
There is rubber, and there is black material that looks like rubber, such as EDPM, nitrile rubber, and others. Oil rots/swells rubber, and yet many engine seals are made of a rubber 'like' material.
As my old chemistry teacher, Frankie Marsden, said, "all pennies are round things, but not all round things are pennies". If you know Frank, tell him that at least some of what he said sunk in!
^^^ Can't dispute any of the above - but it still doesn't, settle the matter of whether push fit polypropylene waste and/or overflow is suitable or approved for condensate.
Dare I say it's sounding like they just pushed it together and that was that. In all honesty the waste from my kitchen sink (the bit outside the house, not inside) has been fitted thus for the past 15 years .. it means I can pull it apart to clean the hopper occasionally and it hasn't leaked at all - but, of course, it should really be permanently joined with solvent weld cement.
You can tell polypropylene push fit from solvent weld ABS (plastic) as the solvent weld glue won't stick to polypropylene, but it melts the ABS stuff. If you get a tub of solvent weld cement you can do a permanent job and it won't leak.
