Immersion heater themostat temperature settings should be taken with a pinch of salt....it's common to find they are 10 degrees out even when they are brand new and have been "sealed" by the manufacture to indicate they have undergone testing.
A 13 year old Ecotec is riddled with design faults...leaking diverters, failing expansion vessels, poor quality pressure sensors, rubber hoses suceptable to debris buildup etc.
Most of those faults you've listed are due to lack of proper maintenance, system water quality (Vaillants need German unicorn tears) and poor boiler design.
AAVs and pressure sensors are almost a routine maintenance part changed every few years...
Fill to 1 bar max (unless there's an excessive height from boiler to top floor rads)...any more pressure and you'll give yourself more problems.
