Vinyl flooring on chipboard flooring
5 Dec 2012
i have just completed my log cabin flooring and currently have loft board as my sub floor.
i want to lay vinyl flooring on top of this.
what do i need to do in order to complete this job?
How does i secure the vinyl around the edges?
Does vinyl literally just sit on the floor and secured via tape at edges? Is tape suitable on wood?
thanks
Is the loft board nice and flat with no gaps or raised or sunken bits at the edges?
If so lay straight on top , you can either tape or use spray adhesive it's upto you , if it's the cushioned type of vinyl you only need to do the edges (and joins if you have any)
i left gaps at edges for expansion... maybe ill have to stick to my original idea of laminate?
thanks for info
Vinyl over 4m2 should all be glued down so you would need to plywood it 1st. If going laminate look at quickstep impressive. It has hydro seal so you can get it wet.
