- Joined
- 11 Jan 2004
- Messages
- 46,522
- Reaction score
- 3,805
- Country
Post photos of both external connection points.
As in these cables right (highlighted in red crosses)? The coax being the thick broadband one right?Cut the cable inside the junction box so you can make it look tidy. Just don't cut the coax only the phone line.
The photos on the original point details all the connection points - inside house, outside cable running through, telewest junction box. From the junction box, the cables just run underground.Post photos of both external connection points.
No, it goes straight into a pole just down my street.Does the BT cable go to a JB before it goes to the pole?
The cables looked pretty messy, even for someone who knows absolutely nothing about this! But I was much more scared by the MASSIVE spider nest I found inside (photos were after cleanup..), must have been a good hundred of the little buggers running around!! Mum-spider didn't looked pleased either!Cut the cables outside in the External brown box just underneath the Jelly Crimps so the cable serving you could still be used. Remove it all, looks a p Poor installation anyway! I used to work for Telewest in West London to Maidenhead and some of the contractors were pretty ****
Thing is, I have another Virgin/Telewest feed into my house, similar to this:Is it the master socket where the black cable is the feed from outside and the other grey 4 core goes to one, or more, extension sockets. I had one similar to that on my old BT system.
Just underneath the clear jelly crimps or where your Red crosses are on your photo - you don't have to be that accurate!The cables looked pretty messy, even for someone who knows absolutely nothing about this! But I was much more scared by the MASSIVE spider nest I found inside (photos were after cleanup..), must have been a good hundred of the little buggers running around!! Mum-spider didn't looked pleased either!
Would you be able to highlight specifically where to cut the cable? Just trying to avoid any pains for myself in the future (also highlighting how little I know about this stuff...).
Thank you!
