B
Bodd
Pictures of the fish/pond please.
Andy
It's more of a tank than a pond....
One of the fish said who knows how to drive this thing.
Andy
Dunno what a SWA is but it’s a crinkly tube with a single 2.5mm inside spurred off of a socket in my garage. Goes straight through the back of the shed directly into the back of a twin surface socket which runs a small freezer, a tumble drier and, via another 5a spur, the lights in the shed.I'm sure that SWA shouldn't be attached to that fence.
There's your next job Mottie, get it sorted before someone from the electrical section sees it. Good job BAS isn't still on here!![]()
Dunno what a SWA is but it’s a crinkly tube with a single 2.5mm inside spurred off of a socket in my garage. Goes straight through the back of the shed directly into the back of a twin surface socket which runs a small freezer, a tumble drier and, via another 5a spur, the lights in the shed.Been there about 5 or 6 years with no problem.
Seriously - what could realistically go wrong? I replaced the 2.5mm cable going to the garage about the same time and that had been there since we moved here in 1990 so that had lasted at least 25 years. I only changed it because it got damaged when I was taking a concrete post out of my concrete drive and chopped halfway through the garage cable with a kango. The power cable was run inside another pipe buried in the ground. I managed to repair the pipe and draw a new cable all the way from my fuse box to the garage. It was the old stranded 2.5mm T&E cable so quite old and had probably been there many years before we moved in. Wouldn’t surprise me if it had been there since the house was built in 1960.5 or 6 years closer to a problem then![]()
Basically 2.5mm T&E degrades in the sunlight.....
with so many plastics that are near indestructable in the enviroment and will probably never ever degrade and go on polluting that planet for about ever. Why did they make a clothes peg that rapidly falls to bits in sunlight?I've been very lazy during furlough and, despite my enthusiasm for hanging out washing, I'm less keen on fetching the clothes pegs off the line afterwards. So, there they remain between washing loads.
And, in this intense sunlight, the plastic is degrading and breaking inside of a month. OK for a clothes peg, not so for something with 240v coursing through it![]()
we too have such wonderfully designed clothes pegs, wonderful for the supplier as we will need to buy more. What a feck-wit species we are.
