Hi this post in on behalf of a friend's neighbour who is in a boundary dispute with a neighbour who is building a single storey rear extension that required Planning Permission (which has been granted). The property that is having the extension is detached.
The outer leaf of the side wall of the extension, that which faces the neighbour, is being constructed out of concrete blocks running parallel with the dividing fence at approximately 100mm from the fence. The rest of the walls, those that the owner will see, are being constructed in red brick.
The issue is that if the fence, covering the concrete block wall, is either removed or falls apart and is not maintained the neighbour will be left looking at an ugly concrete block wall.
Is building the side wall that faces the neighbour, regardless of who owns the fence or whether the fence is removed or not, a breach of the Building Regs and/or Planning Regs.
The planning application states that the materials used will match the existing building, which is red brick at the ground floor level.
