Yes ,with a liberal coating inside fitting and outside pipeSorry, just to clarify, I can solvent weld in the same place on the pipe as long as I clean it up ok?
Those crossing copper pipes look a bit close together or is it camera angle that makes it look that way
If you've already had a solvent weld joint, there is no way you should be able to get it to come apart. Solvent weld is exactly that - a WELD. If you can get it apart then either the materials are not correct (pipe, joint or 'glue') or the mating surfaces were seriously contaminated with something like silicon lubricant.
Solvent weld sets in minutes, if not seconds, so I don't think it would be that.TBH, I don't think I let them set for long enough
What solvent cement are you using? Are you using enough? Are the fittings loose or tight on the pipe?
