Can anyone identify this roof tile please ?
27 Jul 2006
Now i know its a Marley as its stamped on the back but the top of the tile is broken off so i can't take an exact measurement
That said, its 332mm wide and +412mm (the broken length)
So can anyone confirm that this is a Marley Ludlow Major please ?
2nd question.....
I'm looking to replace one of these tiles with a built in vent to duct the steam from an extractor fan over a shower
Can anyone confirm a good manufacturer of tile vents please ?
Thanks in advance as always (y)
Ludlow Major
You want a roof terminal not a tile vent - unless the vent can act as a terminal too. Klober,Ubbink, Glidevale are common.
Ludlow Major
Woody, thanks for the reply !
Can you confirm that if it mentions "....or mechanical extraction", then that means it is suitable for an extractor fan please ?
These Klober and Ubbink links below mention "vent" but not "terminal" in their descriptions on these links :
Klober / Limarech Vent
http://klober.co.uk/media/uploads/56c487135aed8.pdf
quote "Adaptor and Flexipipe available for soil ventilation or mechanical extraction"
size = 418mm x 332mm
Ubbink
http://www.ubbink.co.uk/ubbinkcouk/media/Ubbink-UK/Literature/UBBINK-UB19-Ludlow-Major.pdf?ext=.pdf
quote "Mechanical extraction when used with the Felt sleeve and Stepped Adaptor"
size = 420mm x 330mm
http://www.ubbink.co.uk/ubbinkcouk/media/Ubbink-UK/Literature/UBBINK-UB62-MLM.pdf?ext=.pdf
quote "Mechanical extraction when used with the Stepped Adaptor"
The Glidevale G5 mentions its both a ventilator/terminal :
Glidevale
http://www.glidevale.com/uploads/7120e313d36c436977fdbb32039763c4.pdf
Have you any experience of any of these (Klober, Ubbink or Glidevale) in terms of quality, fitting and price please Woody ?
So to fit one of these tiles, i'll need to cut a hole in the sarking felt
Can anyone confirm how do you "make good" to prevent any water getting in to the loft, if water were to get under the tiles please ?
With a pair of scissors. The terminal should be installed to prevent water ingress so don’t get hung up on sealing it
If there is a felt lap above its simple. If not, glue a deflector strip above the flap of felt.
You cut the felt in an incomplete square, i.e. low front and two sides and fold the flap back up the roof. Prior to folding it back, slip in a deflector piece that gets folded up with the flap.
You can make your own vent with a pitched flexi slate, a mushroom cowl and a short length of pipe. Oh and a wee bit of timber cradling internally. It is better (if you can) to locate the vent exit smack on a tile joint.
