A few soil stack questions before I order...
12 Apr 2020
I can only find 92.5 degree 110mm elbows, and while this makes sense to get a fall, what about when the elbow is used horizontally to go from a horizontal 110 pipe into the house to connect to the toilet? Surely then I just want a 90 degree elbow? If anything the extra 2 degrees will point it further from where I want it to go internally?
Or is it too minimal to matter?
And also, I currently have a 110 straight coupler about 20cm from the ground where the pipe emerges. Can I just leave this or should I replace it with an access socket for rodding?
Yes, it will work as a 90° no problem.
You could rod from the top but may be worthwhile putting an access in as you are replacing it all anyway.
So do you not get 90 degree elbows? Are they all 92.5?
yeah maybe you're right, I could replace the straight coupler at the bottom with an access connector instead
It wouldn't make sense to manufacture two different bends with a 2½° difference. There is more than enough play in the joint for it not to matter at all.
