KARCHER pressure washer - motor fault
21 Mar 2010
Kent
Hiya you knowledgeable people,
OK, I have a KARCHER 390 old model. its been fantastic up until now. First issue was, it suddenly stopped working done some digging and found it had a leak on one of the cylinder head seals ok replaced that stopped the leak. All good I thought but no. With the cover off water on full, and hold the trigger fully open and push the fan on the back of the motor it springs into life BUT as soon as I let go of the trigger it will not start again until I push the fan and then its fine until I release the trigger then back to square one again. is it the Brushes? if yes how do I do that ?
Check out the motor capacitor first, look for burning or any discolouration.
These components instruct the motor in which way to spin, and if its faulty this is the symptom you get.
John :)
John :)
Hiya John, I think you've hit the nail on the head.
When I prod the fan it spins to the left and when I do it again it spins to the right.
Where is the Capacitor located? Would it be in the little black plastic box on top of the unit.
Thanks for your help
regards Colin
A motor capacitor is generally a shiny aluminium cylinder (closed ends!) often bolted to the motor itself or certainly nearby. It will be marked with its working voltage and capacitance measured in microfarads or uf.
Typical voltage could be 400v and capacitance 4uf.
We’d need a photo for more recognition I think.
John :)
Thanks for that I will have a look in the morning when I get home from work.
many thanks
John :)
I couldn't wait until the morning John
Hi John,
I've located it,
on my unit it has this,
Icar Italy Ecofill
WB 40200
20 UF
AC 400V
And the closest I've found is,
Icar Italy Ecofill
WB40400
40UF
AC 400
is this any good?
Hmmm certainly the working voltage is fine but the capacitance -40 against 20uf.
I’m afraid I’m not able to comment if that is ok or not and no idea what difference it would make but I’d prefer to get one nearer the original rating.
John :)
Not important> Icar Italy Ecofill
Not important> WB 40200
Most important> 20uF (must be at this value)
Make sure at or above> AC 400V (no issues with this being AC450V or AC500V).
You will want one of these:
ebay search "Karcher 20uF"
https://www.ebay.co.uk/sch/i.html?_...0&LH_TitleDesc=0&_osacat=0&_odkw=katcher+20uf
Or these:
Google search "Karcher 20uF"
https://www.google.com/search?client=firefox-b-d&q=Karcher+20uF
Or if you have the money this is likely to be closest to OEM:
https://www.espares.co.uk/reviews/es538532
SFK
If the wrong capacitor rating or a poor quality capacitor is used, then the motor will not have the correct phase angle between the current and the voltage, and consequently the motor torque or rotational force will be affected. Depending on the motor load, this may result in a reduction in the motor's overall speed.
No idea what the tolerance is. Would need to know inductance of motor i presume.
