    Dismiss Notice
KARCHER pressure washer - motor fault
Discussion in 'Appliances' started by pen4uk, 1 Jul 2020.
  1. pen4uk
    pen4uk
    21 Mar 2010
    66
    Thanks Received:
    Kent
    Country:
    Hiya you knowledgeable people,
    OK, I have a KARCHER 390 old model. its been fantastic up until now. First issue was, it suddenly stopped working done some digging and found it had a leak on one of the cylinder head seals ok replaced that stopped the leak. All good I thought but no. With the cover off water on full, and hold the trigger fully open and push the fan on the back of the motor it springs into life BUT as soon as I let go of the trigger it will not start again until I push the fan and then its fine until I release the trigger then back to square one again. is it the Brushes? if yes how do I do that ?
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    Check out the motor capacitor first, look for burning or any discolouration.
    These components instruct the motor in which way to spin, and if its faulty this is the symptom you get.
    John :)
  4. jj4091
    jj4091
    1 Dec 2006
    5,117
    Thanks Received:
    477
    Cumbria
    Country:
    • Like Like x 1
  5. pen4uk
    pen4uk
    21 Mar 2010
    66
    Thanks Received:
    Kent
    Country:
    Hiya John, I think you've hit the nail on the head.
    When I prod the fan it spins to the left and when I do it again it spins to the right.
    Where is the Capacitor located? Would it be in the little black plastic box on top of the unit.
    Thanks for your help
    regards Colin
  6. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    A motor capacitor is generally a shiny aluminium cylinder (closed ends!) often bolted to the motor itself or certainly nearby. It will be marked with its working voltage and capacitance measured in microfarads or uf.
    Typical voltage could be 400v and capacitance 4uf.
    We’d need a photo for more recognition I think.
    John :)
  7. pen4uk
    pen4uk
    21 Mar 2010
    66
    Thanks Received:
    Kent
    Country:
    Thanks for that I will have a look in the morning when I get home from work.
    many thanks
  8. SFK
    SFK
    23 Jul 2010
    1,945
    Thanks Received:
    451
    Oxfordshire
    Country:
    • Thanks Thanks x 1
  9. pen4uk
    pen4uk
    21 Mar 2010
    66
    Thanks Received:
    Kent
    Country:
    I couldn't wait until the morning John
  10. Sponsored Links
  11. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    That’s pretty high for a motor start cap.....oh well! Plastic or metal, the markings are the same.
    John :)
  12. pen4uk
    pen4uk
    21 Mar 2010
    66
    Thanks Received:
    Kent
    Country:
    Hi John,
    I've located it,
    on my unit it has this,
    Icar Italy Ecofill
    WB 40200
    20 UF
    AC 400V
    And the closest I've found is,
    Icar Italy Ecofill
    WB40400
    40UF
    AC 400
    is this any good?
  13. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    Hmmm certainly the working voltage is fine but the capacitance -40 against 20uf.
    I’m afraid I’m not able to comment if that is ok or not and no idea what difference it would make but I’d prefer to get one nearer the original rating.
    John :)
  14. SFK
    SFK
    23 Jul 2010
    1,945
    Thanks Received:
    451
    Oxfordshire
    Country:
    Not important> Icar Italy Ecofill
    Not important> WB 40200
    Most important> 20uF (must be at this value)
    Make sure at or above> AC 400V (no issues with this being AC450V or AC500V).
    You will want one of these:
    ebay search "Karcher 20uF"
    https://www.ebay.co.uk/sch/i.html?_...0&LH_TitleDesc=0&_osacat=0&_odkw=katcher+20uf
    Or these:
    Google search "Karcher 20uF"
    https://www.google.com/search?client=firefox-b-d&q=Karcher+20uF
    Or if you have the money this is likely to be closest to OEM:
    https://www.espares.co.uk/reviews/es538532
    SFK
  15. Burnerman
    Burnerman
    7 Feb 2008
    23,073
    Thanks Received:
    4,483
    Northumberland
    Country:
    Anyone have any ideas what happens if the wrong value capacitor is used?
    John :)
  16. SFK
    SFK
    23 Jul 2010
    1,945
    Thanks Received:
    451
    Oxfordshire
    Country:
    If the wrong capacitor rating or a poor quality capacitor is used, then the motor will not have the correct phase angle between the current and the voltage, and consequently the motor torque or rotational force will be affected. Depending on the motor load, this may result in a reduction in the motor's overall speed.
    No idea what the tolerance is. Would need to know inductance of motor i presume.
    • Thanks Thanks x 1
  17. jj4091
    jj4091
    1 Dec 2006
    5,117
    Thanks Received:
    477
    Cumbria
    Country:
    In the old days if it was a long way out of tolerance the motor would lock up & begin to smoke, probably because of SFK's description
    • Thanks Thanks x 1
Loading...
Share This Page
