Project is to replace a damaged, leaking flat garage roof. The roof consists of a thin fibreglass layer supported by OSB panels, which in turn rest on purlins and joists. The roof doesn't drain properly and the fibreglass has cracked, leading to the underlying OSB rotting. The joists were obviously treated with something and still seem to be OK.
I want to replace with sloping corrugated roof, preferably galvanised steel. For simplicity the slope can be from one side to the other instead of a ridge.
I already know that I can buy corrugated sheets which will span the entire width of the garage (only about 2.5 m) but what is the minimum amount of support I can get away with? It would be nice to only have to bolt the steel down on either side and not have to build a sloping rafter/purlin support structure.
What would be a durable and relatively simple method to build up the wall on one side and fill in the triangular gap at either end? The tops of the cement sheets are about 10 cm thick so I thought about using narrow breeze blocks, but not sure how well they would stand up to wind or getting knocked about. Maybe bolt some angle irons on the interior side to support the blocks laterally?
