Hi just the above really, just wanted to know if strips are now obsolete and the sparks are all using wago type, lever or push ?
Almost, just an odd time when space is tight I will use a choc block
Yes some light fittings are a bit tight when you might have four or more wires to connectI assume you mean space to fit the Wago as opposed to space to do the connecting?
Me tooWe had a run of clear 15 amp connecters that were so thin they split when tightened, put me off using them after that and only used the White case ones
