Worcester Camray 18/25 utiity boiler
19 Jul 2020
Please see https://www.diynot.com/diy/threads/gas-fitters-only-forum-the-combustion-chamber.114690/
Hi all,
I am relatively recently OFTEC qualified and have been asked by a customer to service the above boiler, having done a few Heatslaves this one is looking like a pig. I am struggling to work out how to get to the baffles to remove them, presumably they can not be removed through the primary heat exchanger access panel so do I need to effectively remove the whole of the secondary heat exchanger to get to them?
Any advice would be great.
Cheers
Dunk
My post was removed for the reason it was “gas advice” but don’t understand why as it was guidance on baffle removal.
All this information can be found in MI left with householder?
Obviously the "OVER ZEALOUS MODERATOR" does not realise that this is an OIL FIRED APPLIANCE !!!
There are three access covers.
One on flue manifold 5 screws
One on access panel.
And the obvious one where burner mounts.
Downloadhttps://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi7k5aDtdnqAhXMShUIHc2cCpcQFjACegQIARAB&url=https%3A%2F%2Fwww.worcester-bosch.co.uk%2Fprofessional%2Fsupport%2Fliterature%2Fgreenstar-camray-utility-and-utility-system-installation-instructions&usg=AOvVaw1R10IxAwUwD9e_BbPoVdZy
