- Joined
- 22 Oct 2015
- Messages
- 82
- Reaction score
- 5
- Country
Evening all,
So I'm currently renovating the living room in our victorian end terrace.
As part of this, I've removed the old gas fireplace that we never used, and have built the chimney breast out about 40mm in order to provide some more depth for alcove bookcases.
I'm now working on lining the builders opening.
I'd originally intended on using normal plasterboard; however I then had the thought about how to handle damp etc, as it's a capped chimney behind.
Is normal plasterboard suitable, or should I be aiming to use MR Plasterboard or cement board such as hardiebacker.
One side and rear is going to be fixed to studwork, but the other side is going to be sticky foamed onto the brickwork and screwed at the front.
This is what it looks like right now:
Once boarded, the fireplace is going to be plastered and painted, and left as an open space for ornaments or similar.
Thoughts?
Thanks in advance.
Gavin
Thoughts?
Thanks in advance.
Gavin
