What size hole saw?
17 Dec 2018
Does anyone know the hole saw size required for a UK standard plugtop to pass through?
I'd plan to fit a socket in my kichen base unit, so that my washing machine can be assessed and switched on/off without pulling the entire unit out
Huh? Holesaw ? "plug top" assume you mean socket? Still don't understand.
EDIT: You want the min sized hole for a plug to pass through, yes?
10mm
because you can push a cable through and then put a plug on the other side.
I like white duraplugs or toughplugs because they are slightly resilient and not easily cracked
When you buy a new plug, it has a cardboard illustrated fitting instruction attached
https://www.screwfix.com/c/electric...category=cat8800007&amprating=13_a&price_to=2
If somebody tells you that removing a factory plug voids the guarantee, they are talking nonsense.
10mm
Depending on socket location, that could impede pulling the machine fully out.
Use a pair of dividers and transfer the measurement; use the next size up hole saw. Test on paper first if unsure.
Blup
Actually holes neatly cut don't look too bad.
Inside a cupboard so not really seen anyway.
It's when people use a hammer to 'cut' them they look terrible.
A desk grommet can be put into the hole, if having a hole in a concealed cupboard is a problem.
Removing and refitting a plug is not an option for people who have appliances delivered and expect them to be 'installed' (plugged in) by the delivery person.
