how do I remove scratches on a new sink, I used a scrapper to scrape off plaster, now there are scratches on the sink. Is there a cream you can rub in ( like t-cut on a car ) or some sort of paint ????to get rid of them.
joe-90 said:They won't actually be scratches but deposits of steel on the glaze (similar to chalk on a blackboard). The glaze is actually a layer of glass so you want something to T - cut the glass. If I were you I'd try a lapidary supplier who sell a cheap rare-earth element for stone polishing called Cerium Oxide.
I've used it for such things in the past. Worth a try.
Try one of these for a fiver.
http://www.totalbathrooms.co.uk/Care-and-Repair/Cramer-Bath-Rubber[/QUOTE]
Bought one of these rubbers, and it did the trick at removing what they call 'Metal Marks' from the ceramic.
They have changed the link though, its now
http://www.totalbathrooms.co.uk/Cramer-Bath-Rubber
Hope that helps you out also![]()
Ive just installed a new basin and whilst fitting my watch must have been rubbing on the side, when i was finished i nearly died i noticed 3 or 4 scratches on the oposite side.
They are like black marks look like scratches but not deep at all
Is this all i need to remove them the rubber as mentioned earlier (i need to get them off my partner not impressed)
Regards
Kev
