I am about to start a loft conversion and used my neighbours buildings regs as a basis for mine. I didn't want to use steel to support the floor so got the structural engineer to alter the neighbours design to use additional joists (20cm spacing instead of 40cm). At the time I asked him why he used steel but he couldn't remember (he is retired). However, today I think I found out why as when taking a closer look in my loft to locate the supporting walls (my regs are currently under review with the council), I realised that at one end, the existing joists are not actually resting on a wall plate but are nailed to the rafters (it's a Victorian house). The reason for this is that in the room below, the edge of the ceiling slopes backwards from the window following the external roof line so essentially the end of the joists are 50cm or so back from the external wall.
Obviously I can't have my new joists resting on the ceiling and I will need to consult building control but does anyone have any suggestions as to how I might be able to support the new joists? My thoughts are that I remove sufficient roof tiles up to where the joists are visible (I need to do some work on the roof anyway) and for each new joist I add additional timber in parallel to the adjacent rafter (nail the new timber and rafters together) and create a flat platform at the top onto which my new joists would sit. Essentially I guess I would be doubling up the existing rafters. Does this sound like a plausible option?
