Is that ........Re: gutter (at) the back of the house.- supply and fit new drain pipe. 2 new gas cowls ? Gas Safe work ? Refix lead.Does anybody else think this sounds awfully cheap?
Re gutter the back of the house. Supply and fit new drain pipe.
Supply and fit 2 new gas cowls.
Refix lead on chimney stack and on front porch £395
Hi Nige, that is correct.Is that ........Re: gutter (at) the back of the house.- supply and fit new drain pipe. 2 new gas cowls ? Gas Safe work ? Refix lead.
Not had others yet. I just know somebody who paid hundreds just to have chimney re flashed.How much are the other quotes? Sometimes 'cheap' is very expensive.![]()
Easy job? How come it needs re fixing ?They re quoting to "re-fix" the lead which might be a fairly easy job.
It's starting to come away from the chimneyEasy job? How come it needs re fixing ?
obviously not that easy then... otherwise it would still be in placeNo idea, I haven't seen it.
