Looks good, next time remember those toppers!
Thanks, I won't forget that in a hurryLooks good, next time remember those toppers!
Did you lead clip the top?
Not sure what you mean, are you asking if I clipped the overlapping layers of lead flashing together? If that's what you are referring to, I cut out the pattern, leaving 'flaps' that folded over and keep the layers secured together.
Turn the top eave batten on edge...btw you don't need 100 on verticalMorning all,
Setting out today and following the advice to have an eaves tile at the top.
Can't work out how it's possible to do this without having to stick to the 125mm exposure that
It creates. The plain tile below the eaves touches the batten above resulting in the 125mm exposure.
The photo shows an eaves tile at the top and a full size below on the left and two eaves tiles on the right which just shifts the problem downhill
A full size tile at the top allows for 100mm which is what I'd like to achieve but I can see that this results in a bigger lead flashing.
Am I being daft? Or is this just how it is? I've seen lots of bays done with a smaller exposure. Can I just tile the whole thing in eaves tiles to get the tighter rows?
This has been really useful to read chaps as I'm tackling a similar project tomorrow. I'm planning on avoiding the need to bend wooden battens by using upvc. Before I start, any reason this isn't a good idea?
that is because it should be a tray fitted under the cill and frame. flashing as you suggest is not correct as i have previously said.I'm stumped at how to secure the flashing in the gap at the top
Looks like that may be my only option. Will need to shim the gap a bit first though.Flashing clips and lead seal.
