Gas hob
7 Apr 2020
Hello does anyone know what hose goes on this gas hob need to supply parts for engineer. They are normally a female so i male hose does on but obviously not on this bosch model
1. Nearly all gas hobs have to be hard piped in copper (or steel, NOT plastic) these days.
2. Check the installation instructions to see if yours is one of the few exceptions.
3. If it is an exception, then get the hose as a spare part from Bosch.
4. The engineer should supply any parts needed - not you.
Your installer will be able to supply the correct parts for you. A hose may or may not be acceptable, depending on a number of factors. It may need to be hard piped in copper
The gasman is on holiday in a place with no internet and no mobile phone, and has arranged to call in on his way back from the airport with no time to collect his van or call in to the merchant.
His brother's an electrician, and crops up quite often.
I don't know how the pair of them get any work done. I've never known a day when they weren't on holiday.
LOOL. anyway so why do they sell a gas hob hose if it has to be hard piped with copper??
