Hi All
I would like to open up an existing doorway into my extension, currently there is a 1350mm opening which i would like to extend to 2000mm. Lintel would be 2400mm in length.
There is a lintel of some description already in there but it is crumbling away and would like to replace BUT have no idea what to get
I have been on the catnic website and that is suggesting a CN81C which seems to have a SWL of 54kN but not sure if that is enough.
Its on the ground floor and will be holding up the external wall above. No cavity, 215mm thick wall 2 bricks thick. If i knew what the loading was this would be easier but i don't. Is there an easy way to work this out?
Is there a belt and braces solution ie a steel which would cover much more weight or should i just get the catnic?
