I levelled a patch of earth for a 9’ x 8’ shed I’m building myself. It’s using ecobase plastic grid system.
I thought it seemed all level with the spirit level. Finished the stud walls today and clearly the top front beam is not level with the back one. I think it’s the front left corner too high.
I’m trying to find out my options.
I didn’t get concrete as I’ve had no local builder return my query. I don’t want to do it myself I’m sure that won’t be level, hence ecobase grids.
I could dismantle the walls and try to level the earth again. But I thought I did first time so there’s no guarantee I’ll do it the second time. Don’t want to reassemble shed to find out. Also don’t know if it’s a small area or if it’s a large area, whole thing could be a slope for all I know. Spirit levels are not accurate over long distance.
I wondered about using spacers/shims on the lower end, but what do I use for this? It’s various heights as it slopes up to the high point. I don’t want a slab in one corner and that’s it.
So I then wondered about these plastic adjustable feet you can get. They seem like a good idea I can put them on the ecobase. But they’re plastic, bit concerned they’ll break under the weight.
just wondered what are the best options. I’m trying to reduce costs too.
thanks
thanks
