I'm thinking of a 4mm radial circuit on a 32 amp MCB. The socket nearest the MCB has to carry the full current of the radial and this could approach 32 amps. Is this OK?
As has been said, the socket certainly won't carry 32A (or anything approaching it). As also said, the conductors connected to the nearest socket could carry up to 32A; the great majority of that current will usually be through the direct contact between the two conductors, but a very small proportion (certainly not enough to give rise to any concern) will travel through the material of the terminal.I'm thinking of a 4mm radial circuit on a 32 amp MCB. The socket nearest the MCB has to carry the full current of the radial and this could approach 32 amps. Is this OK?
That is OK. We live and learn. Do you know how to create the small 2 on a Mac or iPhone?Do you mean 4.0mm²? 4mm is a measurement of length and not a cable size.
I know everyone knew what you meant, but I thought I’d be unnecessarily pedantic and self righteous to see how you like it.
Yes, of course it is - but one has to scroll down a fair way for the numeric superscripts.Isn't it under the Ω symbol (then scroll down) above the reply box on the site? Nothing to do with the device being used.
True - although, as has been said, that is not necessary for many special characters (like Superscript 2 and Superscript 3) within this forum, since they are available from the drop-down list in the 'reply' window.... On a PC (not a Mac) you can enter a load of special characters by pressing and holding the Alt key, typing the ASCII code for the character, the releasing the Alt key. Superscript 2 is Alt-253 - ², superscript 3 is Alt-252 - ³.
what you describe only works if one types the ASCII code using the numeric keypad
if one types the ASCII code using the numeric keypad - it does not work if one uses the 'usual' numbers across the top of the keyboard.
Sure, but the question obviously related to posts within this forum.Key words there being "within this forum", using Alt-nnn works everywhere and so is, IMO, a lot more useful.
You're welcome. In fact, I'd forgotten myself until I decided to just check that it did work in this forum's reply box (funny quirks have been known to happen)!Damn. I know that and thought of it but forgot to include it. Thanks.
Practices and preferences obviously vary. I personally only switch on the numeric keypad when I am entering numerical data etc. Otherwise, I keep it switched off, because I find it useful (on my laptop) to have the Home/End/PgUp/PgDn keys constantly available - so, for me, the number keys at the top are "the usual"!Hmm, not sure I'd call them usual. I only ever use those keys for the the shift characters. Most of the time when I am typing digits I am entering multiple ones and so the numeric keypad is much easier. So even if it was just a single digit I would use the numeric keypad.
Fair enough - that is your prerogative.I disagree.
I sometimes plug an external numerical keypad into a desktop, but would rarely, if ever, do that with my laptop, since 'I use my laptop as a laptop'. Very few people have external keypads.I, almost always, plug a keyboard into my laptop.
Fair enough, but I'm not sure what you would call it, then. The vast majority of our readers will not have external keypads (for any Windows-based device) and will presumably call that part of their keyboard their "numeric keypad".I would not call what you are talking about a numeric keypad.
In any event, as you understand, my point was that, no matter what you call it, that part of their keyboard is what most people will have to use if they want to use the ALT-code method of inserting special ASCII characters.
