I suppose I have to take your word for that, but I have to say that I don't recall having seen any terraced/semi houses with 'sheds adjacent to the front door' - and I'm not even sure what the Planners would have to say about sheds in front gardens! Do you really mean 'shed', rather than some sort of 'cabinet'.In my experience 'Two Services' is extrememly common, in 70's it was very common to build terraces/semi's with a shed adjacent to the front door which contained the services, the gas, water and electric supplies often came up in one and then teed to the neighbour with the leccy coming from a second fuse in the head.
If there is joint access' to the 'shed', then I suppose that's not too bad. However, that's not really what we have been talking about (and is more akin to the multi-occupancy buildings you go on to mention). If the equipment is within one of two dwellings, then there are clearly some potential issues (in relation to both 'safety' and logistics/convenience) houses if the DNO fuse for one dwelling is within the other (and not necessarily always easily 'accessible').
Sure, but that moves the goalposts well away of the situation we're discussing.Multi occupancy buildings [conversions] often have several whole installations in one space with only one head[RF Lighting has posted several pictures]. I assisted with a fusebox change very recently which has a 3ph supply and Henley blocks before the meters feeding 7 flats. I see no reason to call this 'looped'
I've already discussed that. What matters, electrically, is any part of the cabling which has to carry the combined loads of both installations. Consider the analogy of two 4kW loads in an installation, and two possible arrangements - (a) each fed by a separate 'dedicated' circuit from the CU and (b) both fed by a single 'radial' circuit from the CU. With the former arrangement, the cables from CU to load could theoretically be 1.5mm² (Method C) in both cases. With the second arrangement, the cable from CU to the first load would have to be 4mm² but (if the load were 'unlikely to create an overload', or if there were 'fusing down' after the first load) the cable from first to second load would again only need to be 1.5mm². Those two 'loads' are analogous to the two installations being fed with a 'looped' supply.Ultimately all the power comes from the same place so we could class everything as looped despite the fact that the vast majority is fed like a backbone.
You go on to mention diversity (and Christmas morning). Whilst, under most circumstances, and across many installations, it is reasonable to assume that multiple installations will not simultaneously have high demands, with just two dwellings on Christmas morning one cannot safely assume that they won't both have high demands.
As I've said, the important (and really only) difference between your #3 and #4 is that in one case (#4) each of the two premises has the DNO fuse within it, whilst in the other case (#3) the DNO fuse for 'House 2' is in 'House 1' (and not necessarily always easily accessible to the occupants of 'House 2').I don't believe it makes any difference if it's a link or fuse, the format would be identical.
In terms of loads on cables, in both #3 and #4 the entire load of both premises is carried by the DNO feed to the first house - which is why, in functional terms, I would not regard either as being different from a 'conventional' "looped supply" (your #2).
